Chen12 Posted June 8, 2018 Share Posted June 8, 2018 Hi, I want to use this stairs with the platform as a base for a porch (see image). On the side there should be a door. I created a porch with Home Designer but I can't change the height of the porch. A slab created with Home Designer didn't let me set a door on the side. What can I do? Thanks. Link to comment Share on other sites More sharing options...
solver Posted June 8, 2018 Share Posted June 8, 2018 25 minutes ago, Chen12 said: On the side there should be a door. On the side of what? 25 minutes ago, Chen12 said: I created a porch with Home Designer but I can't change the height of the porch. Have you changed the floor height? Link to comment Share on other sites More sharing options...
Chen12 Posted June 8, 2018 Author Share Posted June 8, 2018 Quote On the side there should be a door. On the side of what? Please see new attached image (orange door). Quote I created a porch with Home Designer but I can't change the height of the porch. Have you changed the floor height? Change the floor height is not possible. See orange circles on second attached image. Link to comment Share on other sites More sharing options...
solver Posted June 8, 2018 Share Posted June 8, 2018 For the door, draw a wall under the stairs and place a door in it. You are asking about floor structure thickness, and not floor height. This is probably another limitation of the software. To make it thicker, add material to the finish floor -- which is currently nothing (0"). Link to comment Share on other sites More sharing options...
