rloverme Posted May 31, 2018 Share Posted May 31, 2018 I just upgraded to HD Pro 2019, and my plan now has some very odd issues in it that I can't seem to fix. The first, most irritating one, is the roof line. Two studs are protruding through the roof, and I can't get them to go away! I've tried adjusting the roof and the walls, but to no avail. Also, with some of my exterior elements, the surfaces are missing or miscolored, and I can't seem to fix them (some surfaces will "take" but others won't, and there doesn't seem to be a rhyme or reason to it). Any suggestions? Link to comment Share on other sites More sharing options...
rloverme Posted May 31, 2018 Author Share Posted May 31, 2018 14 minutes ago, solver said: For the studs, have you tried selecting them and deleting? There may be a wall there -- check the 2nd floor for invisible walls. I have tried that, yes. It seems to be an issue with the walls (which are not invisible, and I hesitate to delete and recreate them). See the detail below when I try to edit the wall. That stud did not appear in HD 2015, but suddenly shows up in HD 2019... Link to comment Share on other sites More sharing options...
rloverme Posted May 31, 2018 Author Share Posted May 31, 2018 18 minutes ago, solver said: Posting the plan file is often the best way to get help. Zip it, and attach as you did the images. 158 Parmenter - build garage.plan.zip Link to comment Share on other sites More sharing options...
solver Posted May 31, 2018 Share Posted May 31, 2018 If this is an existing home, do you have images to post? I'm curious about your use of railing walls that seem to be brick around the front. In a camera view, select the studs and delete. They are part of some unneeded walls. 14 minutes ago, rloverme said: There are two walls on that side. You want to select the invisible one. Copy the 3 windows, delete the wall, go to plan and Paste/Hold Position to put them back. Link to comment Share on other sites More sharing options...
