CanuckDreamer Posted April 29, 2018 Share Posted April 29, 2018 I would like to change the exterior look of segments of the exterior of the house. For example, I am planning a rock look on one face. I also have an exterior wall with cedar siding. However, every time I select the single wall section and try to change the materials, it changes the look of the whole house exterior. If I change wall covering, it is on the interior. See the photo. You can see the cedar wall at the entrance. What do you suggest? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 30, 2018 Share Posted April 30, 2018 Learn the relationship between a default wall's exterior material setting and how you can change a single wall using that wall's "Materials Tab", if you change the default exterior material setting of a wall type, that change affects all such walls in the plan, whereas if you use the wall's material tab, you can change just one wall at a time. You also can use the "Wall Covering tool" to place a single material on a wall's exterior or interior and vary the height of the material change. If your version has a "pony wall" option you can stack two different wall types to create an Architectural look. Anyone trying to help you needs to know what software you are using, its version number and title name. Then, the above suggestions might begin to make sense once you open your Reference Manual and Help files to inform yourself about the above tools I have suggested. DJP Link to comment Share on other sites More sharing options...
CanuckDreamer Posted May 5, 2018 Author Share Posted May 5, 2018 Thanks so much. I have now been able to change the wall using wall covering but it only goes up to the ceiling height. You can see here that the top wedge shape is still grey versus cedar. Screen Shot 2018-05-05 at 1.29.16 PM.pdf Link to comment Share on other sites More sharing options...
