Using Structual Beams with framed walls
TerryEngineer
I have a U-shaped covered porch (3 walls existing, 1 open) and am enclosing the 4th wall. A 4 x 12 beam spans this 16-foot opening (with a center post). Floor joists for the floor above sit on this beam. I want to frame in this 4th wall but can't figure out how to manage the framing to "meet" the beam and still keep the floor joists in their existing place on top of the beam. Thanks for any help.
Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using.
You can help everyone by adding this info to your signature (see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Resources for self help:
It usually helps to attach images and your plan file (close Pro before attaching the plan).
With Pro, you have manual framing, so you can change what is generated by the program.
I'm showing what I think you are describing.
I used a pony wall, with a Room Divider as the upper part of the wall. You would fill in the missing beam and post manually.
