Invisible attic walls
LaurenW
I am using Home Designer Architectural (have tried in both 2016 and 2018) to remove the ceiling above a room. I have designed new simple 4 wall rooms with a gable roof and I have also used an interior template. Once I change the roof to a gable and then remove the ceiling (single story room), the program adds an attic and the walls are invisible when viewed from the interior. However, if you look at the exterior, the walls are there. Can someone please explain why this is happening and how I can correct it? Thank you!
Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using.
You can help everyone by adding this info to your signature (see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Resources for self help:
