Sign in to follow this
keendevelopments
arc above covered entry?
does anyone know if a arc wall can be done using home designer pro? i am trying to achieve arc ceiling at entryway just like in photo.
Please post questions in Q&A. Tips & Techniques is where someone would post a tip or technique.
I see you said Pro, but ...
Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using.
You can help everyone by adding this info to your signature (see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Resources for self help:
You should be able to select the wall in elevation and reshape the bottom as you require. You will be working with the wall polyline, so the break, and change line to arc tools will be helpful.
Sometimes a doorway could be used, but I believe the stone would keep that from working.
thanks for that, i reposed in Q&A
i cant find wall poly line anywhere, could you please explain further. i added i picture of the actual project im working on.
thanks again
