How to lower entire roof
Acropolis
Here is one I have not figured out how to do without redoing days worth of roof work, meaning that auto rebuild is OFF, not an option to auto rebuild roof.
Into build, block construction essentially, constructor left off a row, so instead of 10' walls, they are 9' and the top tie-in structure is in place when it was discovered.
I reduced all the walls and the roof structure stays up where it was at and fills that space with gray material.
Anyone have an idea how to drop the roof onto these walls?
There are numerous reasons to keep the model up to date, so we just leave that as off-topic.
Try clicking on the roof plane and typing -12" after the height that's in that box (this will subtract 12 inches from that original number, easier than doing the math) in the "lock fascia top height" box.
You should include what version of the software you are using, some versions may not have that setting.
