rfcomm2k
Cannot paint a wall
This is more commentary than question, since I already solved it. Just wonder if others have had the same trouble.
I was applying a specific manufacturers material to the exterior gable of the house. I used eyedropper to select it from another part of building, then applied it to the gable. This worked fine. I then rotated the building and used same technique to apply to another gable. It failed.
Eventually, after trying several times, I opened up the wall segment and changed the exterior material there. This time it took, BUT, I had to open it in the attic level, not the second floor level.
Does anyone know of a bug with the material painter tool?
With Exterior Walls it has always been best to Open the Wall DBX and Change it there , due to these weird Issues , especially if for example you do want a different material on the Gable than the main part of the house , ie Shingles vs Siding.
