kirkdebs Posted February 27, 2018 Share Posted February 27, 2018 I have an attic wall that runs between my two offices on the north end of the house. When I color one in one office, the other office's wall gets color, also. So I read the instructions and made sure that the main floor wall is broken and broke the attic wall. I turned off the default walls > general checkbox for attic walls being rebuilt. I closed the dialog box and reopened it and yet is was still unchecked. But when I use either the eye dropper or a dialog box to let the two offices have different paint colors, the attic wall heals into one wall and takes the last color changed. It is reproducible ad nauseam. Enclosed is my HD 2018 Pro file. Sorensen_5.zip Link to comment Share on other sites More sharing options...
kirkdebs Posted February 27, 2018 Author Share Posted February 27, 2018 Thank you Solver for your comments. By the way, I can NOT see your program name or version. Your name, picture and location are visible as well as the large number of posts you have helped people. I did not know I could save a camera in the plan. I will do so next time. The client likes north to point up. So Northern Hemispheric of him. The bend in the house causes me pain every day. But in this case, I do not suspect the bend is the problem with the attic auto rebuild. If you turn off a function, it should not function. How illogical phobic I am. I still consider this case open. Cheers, Kirk Link to comment Share on other sites More sharing options...
kirkdebs Posted February 28, 2018 Author Share Posted February 28, 2018 I thought tech support read this. Live and learn. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 28, 2018 Share Posted February 28, 2018 3 hours ago, kirkdebs said: I thought tech support read this. Live and learn. Some Chief Architect personnel are assigned to monitor this forum but Tech Support has its own communication lines and procedures as listed on the Home Designer website under "Support". This forum is mainly for our use as end users helping each other. DJP Link to comment Share on other sites More sharing options...
