ElkRivers Posted February 27, 2018 Share Posted February 27, 2018 Hello! I am new to Home Designer. I use Pro 2018. I must've accidentally deleted my floor structure in the existing part of the remodel/addition I am drawing. Can anyone out there tell me how I can get it back? I was working with the stairway quite a bit and wonder what I did? Thanks! Karen Blomquist Kitchen Remodel 2018 A.plan Link to comment Share on other sites More sharing options...
solver Posted February 27, 2018 Share Posted February 27, 2018 You can't really delete a floor structure. I've not looked at the plan, but imagine you have walls that are not connected together forming a room, or one or more walls is marked No Room Definition. Check those two things and post back if you still have an issue. Link to comment Share on other sites More sharing options...
ElkRivers Posted February 27, 2018 Author Share Posted February 27, 2018 Thanks. I finally realized the problem was actually that my exterior walls were called out as interior walls...it all looks fine now! Thank you for your willingness to help us get started! Karen Link to comment Share on other sites More sharing options...
