carlosng Posted February 23, 2018 Share Posted February 23, 2018 (edited) Hello I need help to create a bar top on top of standard height island cabinet. Home Designer Architect. Edited February 24, 2018 by carlosng added info Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 23, 2018 Share Posted February 23, 2018 If you have Suite, Architectural, interiors or Essentials you can use reconfigured cabinet parts to emulate the side parts of the bar in your picture. The bar top can be made from a Shelf or soffit (cabinet tools) and also if you have HD Pro you can use a custom slab or custom countertop tools it has. Just think a little "out of the box" in terms of the tools your software has that you can use to emulate objects. DJP Link to comment Share on other sites More sharing options...
kirkdebs Posted February 28, 2018 Share Posted February 28, 2018 I solve this problem by mounting a base cabinet on top of another base cabinet and then configuring the top one as the bar top. Just specify the base height of the top one to be the top height of the lower one. Adjust the countertops to extend as you wish. Link to comment Share on other sites More sharing options...
