b3dh3d Posted February 7, 2018 Share Posted February 7, 2018 I'm designing a remodel for existing attic and I can't figure out how to recreate the current conditions. The room has all four walls as exterior walls. two walls are full gabled with a finished ceiling height of 8' The other two walls are 6' with a partial cathedral ceiling with a 7/12 pitch to the finished ceiling. So basically how do I create a 6' wall that then begins a cathedral ceiling for only a four foot run which then transitions to a normal ceiling with a height of 8' I've been fooling around with this for hours and searching the knowledge base and I haven't found anything to re-create this situation. Any suggestions? Thanks Link to comment Share on other sites More sharing options...
b3dh3d Posted February 7, 2018 Author Share Posted February 7, 2018 Thanks. Just updated signature. To keep things easy I'm using home designer pro 2018 Link to comment Share on other sites More sharing options...
solver Posted February 7, 2018 Share Posted February 7, 2018 I'll assume you are auto building the roof. Set the 2nd floor (Attic) ceiling to 6'. Build the roof. Turn off auto rebuild roofs. Raise the ceiling to 8'. Link to comment Share on other sites More sharing options...
b3dh3d Posted February 7, 2018 Author Share Posted February 7, 2018 Thank you so much! Worked like a charm! Link to comment Share on other sites More sharing options...
