JPalmer3 Posted January 19, 2018 Share Posted January 19, 2018 I have an addition being built on an angle to an existing house. The most sensible way to frame the roof to me involves having a gable carry through the main structure that ends prior to reaching the adjacent wall that is at an angle. I will then need to hang a ledger board on that gable wall and frame a shed roof off of it down to the back angled wall. So, here is the problem....I need to build the back gable wall on top of a beam, as it does not line up with any walls on the first floor. Does anyone have any experience or thoughts on how to attack this? I would even be willing to settle for a way to just generate a gable wall from under the roof so at least the exterior view of the house didn't have a big hole in it! Kirby-back elevation-1-19.pdf Link to comment Share on other sites More sharing options...
solver Posted January 19, 2018 Share Posted January 19, 2018 Please post images directly. No need to make a PDF of an image. To fill in the hole, go to the attic level and draw in your own wall. Link to comment Share on other sites More sharing options...
JPalmer3 Posted January 20, 2018 Author Share Posted January 20, 2018 Thank you for your help and advice. CA premier X10 Beta do you know of any way to build on top of a beam? We also have been trying to figure out how to fill in the gable section of a porch roof that extends out over a beam...thank you, at home on my phone now, so unable to attach a specific picture. Link to comment Share on other sites More sharing options...
solver Posted January 20, 2018 Share Posted January 20, 2018 Chief is discussed on ChiefTalk https://chieftalk.chiefarchitect.com/ 3 hours ago, solver said: To fill in the hole, go to the attic level and draw in your own wall. Link to comment Share on other sites More sharing options...
