dbritti Posted January 10, 2018 Share Posted January 10, 2018 Hello, I need some advice on how to specify the height of the gambrel roof. It needs to be 24'H at the peak but I have 2 floors as you can see in the picture. I don't need full height walls in the loft area. I've tried to reduce the wall height of the 2nd floor (loft and "open below" area) to something like 36" H thinking it would drop the overall roof height, but all it does is add more height to an "attic" wall. Can anyone help? THank you! I'm using home designer pro 2018 on a Mac book Pro. Denise Britti Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 10, 2018 Share Posted January 10, 2018 Were I you, I would create an elevation camera and then measure from the bottom of your building to the target max height using dimension tools. Then you can measure using that dimension to see if your virtual building is too high or low and then adjust the roof plane heights using the "Transform-Replicate" tool to attain the target ridge height. DJP Link to comment Share on other sites More sharing options...
dbritti Posted January 10, 2018 Author Share Posted January 10, 2018 Thank you so much! I have been fighting this for hours and made it work! Link to comment Share on other sites More sharing options...
