erikor Posted January 5, 2018 Share Posted January 5, 2018 I have a wall the extends into a bathroom a few feet to surround a shower. However, the end of wall is raw wood. How do I cover the end of the wall with drywall? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 5, 2018 Share Posted January 5, 2018 Two ways: 1.cover the end with an edited-reshaped soffit set to drywall or whatever material you desire or 2. if your software allows, change the main layer of your interior wall type from wood to drywall. This changes the reveal to drywall instead of wood. I guess there is a third way only if you have Home Designer Pro where you use a custom slab sized to cover the end of the offending wall and set its material to drywall etc. DJP Link to comment Share on other sites More sharing options...
erikor Posted January 5, 2018 Author Share Posted January 5, 2018 Thank you @DavidJPotter, I used the soffit method and that works great. Link to comment Share on other sites More sharing options...
