Trueburton Posted January 2, 2018 Share Posted January 2, 2018 I am doing some final dimensions on this plan and I noticed that there is a 3/4" difference from the 1st floor to the basement walls. I assume it is measuring to a different layer since there are foundation walls in the basement and not on the 1st floor. When the software says it dimension to "main layer", is that refering to the sheeting/OSB? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 2, 2018 Share Posted January 2, 2018 Main layer is the framing or structural layer of a wall. If your walls do not align floor to floor to floor you should use the wall alignment tool to make sure they are aligned to each other, floor to floor. When that is done then the dimensions should match. DJP Link to comment Share on other sites More sharing options...
Trueburton Posted January 2, 2018 Author Share Posted January 2, 2018 Exterior dimensions to sheathing and interior dimensions to the stud? I found a misaligned wall, fixed that part thanks. Link to comment Share on other sites More sharing options...
