wheelers Posted September 29, 2014 Share Posted September 29, 2014 Help, I am a builder and trying to finish up a home design. It is customary in this area to put crown molding on the exterior of our homes below the soffit where it meets the exterior sheathing (i.e.brick, siding,etc). I can get it on the fascia, and i can manipulate a soffit and create it easily below hip roofs, sheds, etc......at this location. My problem arises when I get to the gable. I have tried sloped soffits, shapes, etc- no luck.... advise anyone??? Link to comment Share on other sites More sharing options...
katalyst777 Posted September 29, 2014 Share Posted September 29, 2014 I think this is something that would require an upgrade to the Premier version of the software to accomplish easily.You might be able to create an object like this in SketchUp though, and import it in to Home Designer? 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 30, 2014 Share Posted September 30, 2014 You can apply a molding profile (crown mold) to a soffitt,and resize it so only the crown mold shows and the copy-paste around the outside of you home provided you have either Architectural or Home Designer Pro that is, I do not think Suite, Essentials or Interior Designer will do this, take a look. DJP Link to comment Share on other sites More sharing options...
wheelers Posted September 30, 2014 Author Share Posted September 30, 2014 I have home designer pro 2015. I tried the soffit with crown- which is great for running horizontal or parallel, but I can't rotate it to put it in the gable. where it comes to a point and is diagonal. Thoughts? Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 30, 2014 Share Posted September 30, 2014 Upgrade to Chief Architect Premier, in that application such things are much easier and included. DJP Link to comment Share on other sites More sharing options...
