Samuda Posted December 21, 2017 Share Posted December 21, 2017 I'm trying to create a roof (which I don't know the technical term for unfortunately) and really struggling. I've attached our architect's plans which show the two elevations which help it make sense, plus my normal roofed version made on Home Designer Pro. I've watched every "roof" related video in the tutorials and I have drawn an absolute blank on how the dickens to create it. This is the first design software I've ever used so please hit me with even the most basic thing that I've overlooked or are simply being stupid with! I can't even work out how to link the plan so that you can look at the ins and outs like I've seen other people do on the forum. Any help will be extremely gratefully received. Kind regards Anita 6107 035C Sth Elev.pdf 6107 036A E Elev.pdf Link to comment Share on other sites More sharing options...
solver Posted December 21, 2017 Share Posted December 21, 2017 Do you have a Roof Plan from your designer you could post? Link to comment Share on other sites More sharing options...
Samuda Posted December 21, 2017 Author Share Posted December 21, 2017 Hi Solver. Thank you for your reply. I'm using Pro 2018 so a real newbie I'm afraid and I've added it to my signature as suggested. I've attached the roof plan. Many thanks 6107 024A Roof Plan (1).pdf Link to comment Share on other sites More sharing options...
solver Posted December 21, 2017 Share Posted December 21, 2017 I don't understand how the elevations relate to the roof plan, but take a look at this plan and see what you think. rt 1.plan Link to comment Share on other sites More sharing options...
Samuda Posted December 21, 2017 Author Share Posted December 21, 2017 That's totally it!! :-) I should have said that the elevations show the existing house and the extension with the tippy up roof and the roof plan is just for the tippy roofed extension as the existing house already has a normal flat/shed roof. How did you create it? I'm delighted to know that it's doable! Thank you. Link to comment Share on other sites More sharing options...
solver Posted December 21, 2017 Share Posted December 21, 2017 1 hour ago, Samuda said: I can't even work out how to link the plan Close Pro. Then attach the plan file like you did the other attachments. 10 minutes ago, Samuda said: How did you create it? Are you comfortable with the manual roof tools? This is a fairly simple roof to draw manually, and I'm not sure how to do it easily with the automatic roof builder. Link to comment Share on other sites More sharing options...
Samuda Posted December 21, 2017 Author Share Posted December 21, 2017 Hi Eric I've been using the manual roof tools but clearly not properly as I had ended up with a myriad of weird and wonderful looking roofs that were nothing like what I was after. I had been creating a shed roof using full gables and high gables which is obviously wrong as none of your walls were set as such. If you can explain in an idiot proof fashion then I'll gladly follow your lead. Alternatively, I can re-draw the main plan with the existing house and then the extension built on, like it will be in real life, to divide the regular shed roof from the tippy one and then come back to you? Thank you so much for your guidance; I was floundering! Anita Link to comment Share on other sites More sharing options...
Samuda Posted December 21, 2017 Author Share Posted December 21, 2017 I've attached the plan which I think has the roof planes correctly done but what I can't work out is how to bring the corner of the roof up, and have the walls come with it!? Would you mind please taking a look at it, Eric? Many thanks Anita Samuda ground floor version 1.plan Link to comment Share on other sites More sharing options...
solver Posted December 21, 2017 Share Posted December 21, 2017 Draw the flat roof, setting the overhangs on each side. Make sure the pitch is correct. Draw a diagonal line from one corner to the other. Open the line and copy the angle. Open the Defaults, and under Plan, add this angle -- one negative and one positive value. Take one corner of the roof and form it into a triangle. Draw the tippy up roof starting along the edge of the flat roof and going towards the outside of the house. Use the handles to reshape it into a triangle, snapping the corners to the corners of the flat roof. Set the pitch. Join the two roof planes in the middle. Check in a 3D view. Link to comment Share on other sites More sharing options...
Samuda Posted December 21, 2017 Author Share Posted December 21, 2017 Eric, you are wonderful, thank you so much for taking the time to explain all of that. I'm off to bed now (in England) but I'll try all of that tomorrow after work. I really appreciate your help; you've taught me a huge amount! Merry Christmas Anita x Link to comment Share on other sites More sharing options...
solver Posted December 21, 2017 Share Posted December 21, 2017 Thanks! Post back with questions. Link to comment Share on other sites More sharing options...
Samuda Posted December 26, 2017 Author Share Posted December 26, 2017 Hi Eric I hope you've had a lovely Christmas! I'm nearly there but am struggling to get the two separate roof planes to snap together. The tippy up bit begins lower down than the main part of the roof at the front but higher up at the back and I can't quite fathom out why. I've tried changing the ridge and baseline heights etc. Could you please let me know where I'm going wrong? Very many thanks Anita Nearly right bar roof.plan Link to comment Share on other sites More sharing options...
solver Posted December 26, 2017 Share Posted December 26, 2017 Because the main roof is not flat, you need to tilt the baseline of the tipped up part. Look at the bottom of the roof plane dialog -- (I think Pro has this). It looks like -4.5 (or something close) degrees works. I imagine there is a formula to compute this angle, but I did it by guessing. Draw the roof plane at an angle along the cad line. Change the baseline angle. Raise the roof plane using Transform/Replicate (Z axis). Join the 2 roof planes with the join command. Expect this to be a bit of trial and error. If it does not line up as you want, undo and make a change to the baseline angle. Nearly right bar roof (Eric).zip Link to comment Share on other sites More sharing options...
solver Posted December 26, 2017 Share Posted December 26, 2017 Try -4.45 degrees and move the roof up 455mm. After joining, the join should be along the CAD line. Link to comment Share on other sites More sharing options...
Samuda Posted December 26, 2017 Author Share Posted December 26, 2017 That's worked a treat!! Thank you ever so much! :-) Last thing, I promise......do you know why the upstairs window beneath the tippy up roof has disappeared and been replaced with wall even though it shows as window on the plan? When I look at the framing overview, there is frame across the window. I thought it may have been because the roof had dropped too low and that when I sorted out the baseline height of the roof plane that it would miraculously re-appear; but it hasn't :-( Link to comment Share on other sites More sharing options...
solver Posted December 26, 2017 Share Posted December 26, 2017 I was just getting to that. If you turn on Reference Display (F9), you will see the upper and lower walls are not aligned. Is this the way the house is built? If not align them -- get close then use the Align With Wall Below (or Align With Wall Above) tool. Link to comment Share on other sites More sharing options...
Samuda Posted December 26, 2017 Author Share Posted December 26, 2017 Fantastic! Thank you! It's easy when you know how! I must have tweaked a dimension or two after building upstairs as a derivative of the ground floor. That makes perfect sense, thank you. I really am extremely grateful for all of your help. Best regards Anita Link to comment Share on other sites More sharing options...
