shalinigeorgeint Posted December 9, 2017 Share Posted December 9, 2017 When I apply materials, whether it is imported from an external source or from the library, the actual material is not shown. It is just an overall colour appearing.I have tried "stretch to fit" method, but it doesn't seem to be working. Please help. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 9, 2017 Share Posted December 9, 2017 Imported material textures only show themselves in Standard Render camera views. They will not show in any other camera render types, only Standard. A material, any material is composed of the texture file, for Standard Render views and by a line pattern in all other views. If you did not assign a pattern file, such materials will only show a color in non-Standard render cameras. That is probably what you are seeing/describing. That is the way it is programmed to work. DJP Link to comment Share on other sites More sharing options...
