Maximum .jpg File Size?
tribalco
I have printed out a jpg of one of my room layouts and I noticed that you cannot set the dimensions of the jpg. I am using Interiors 2014 and want to print on 18" by 24" poster board, but when I upscale the jpg in Photoshop to send to Kinkos, it loses a lot of sharpness. Do the more expensive versions allow for larger files? Thanks.
The limitation is set by your monitor DPI and its screen size in pixels.
Chief Architect Permier is the only software application that they make that allows any size possible (I know an English user who created a rendering to be printed at bill board size once).
Home Designer tites, all of them are limited to screen size and native DPI.
the Jpgs HD titles produce are pretty low quality , it may work better with a .png file you could also Print to PDF which should give a much better image as well , you can usually set the DPI in PDF files but not sure how 2014 handles PDF .<br /><br />M.
