grouped rooms
decorators3
There is a built in help system, so when you have a question, it's a good idea to search it first.
A search for explode block would locate the answer, and you would be working instead of waiting.
When an object is selected, the Edit Toolbar contains tools that may be used on the selected object. Mousing over them will show the tools name. When an Architectural Block is selected, Explode Architectural Block will show up as one of the options.
A right click (at least on a Windows PC), will show multiple options, along with the same Edit Toolbar options.
