decorators3 Posted October 20, 2017 Share Posted October 20, 2017 I have CA pro version 2018. How do I change the size of grouped rooms (ie ) bedroom or delete some items to accommodate the plan. thanks Levina Link to comment Share on other sites More sharing options...
solver Posted October 20, 2017 Share Posted October 20, 2017 Explode the block, make changes, re-block. Link to comment Share on other sites More sharing options...
decorators3 Posted October 24, 2017 Author Share Posted October 24, 2017 thank you but How do I EXPLODE the block?? Link to comment Share on other sites More sharing options...
solver Posted October 24, 2017 Share Posted October 24, 2017 There is a built in help system, so when you have a question, it's a good idea to search it first. A search for explode block would locate the answer, and you would be working instead of waiting. When an object is selected, the Edit Toolbar contains tools that may be used on the selected object. Mousing over them will show the tools name. When an Architectural Block is selected, Explode Architectural Block will show up as one of the options. A right click (at least on a Windows PC), will show multiple options, along with the same Edit Toolbar options. Link to comment Share on other sites More sharing options...
decorators3 Posted October 25, 2017 Author Share Posted October 25, 2017 thank you Link to comment Share on other sites More sharing options...
