Shed Dormer Help
charliesnewhome
Hello,
I have created a new design for my next home and I really love the suite software! I have been trying to create a shed dormer in my attic space, but with no luck. I have tried following one of your support articles, but it does not seem to work; it appears to be only for the pro software. Can I create a shed dormer in the suite software? If so, can you provide the steps to do so? Thanks
Creating a shed dormer starts with Edit Default Settings Dormer, where you set up the 3D geometry settings of the intended object. When that is done you then have to place the dormer object on a section of roof where there is enough 3D space to allow the new dormer to exist or to be created. Once you have properly done those things, then and only then will you be able to have a shed dormer.
Posting a copy of your plan and filling out your signature will help others understand the limitations of the software you are using and exactly what your problem or problems are. You know what you want to do but WE do not, help us, help you.
