Extend roof on first floor
GroverJR
Hi, Solver and thanks for the reply.
There are a few problems with this solution (I tried it already): the roof lines won't match unless I adjust the room height, even then the overhang extends beyond the roof line on the second floor, and also the floor of the "invisible front room" creates a porch-like area that I don't want.
If you can make it work with the provided sample file, let me know... :-)
Well, it is definitely getting there. I didn't think about the Open Below to handle the floor, but as you can see in the picture some siding is still showing (odd, huh?) and also when I align the overhangs the overhang over the attached garage vanishes! I've attached the sample for you to look at. Thanks again for the help!
UPDATE: Ok, I changed the foundation to slab and that took care of the lower siding problem. Now if the garage overhang lined up everything would be great.
sample.plan
Edited by GroverJR
Updating
