Stewben
Attic stairs
I have Home Designer 2017.  I have created a plan for a two story house with Gabled roof want to create a stairway to the attic space above the second floor.  If I place a stair on the second floor going up of on the attic floor the stairs always reflect that they go up and in the Framing perspective view the stairs get located between the first and second floors.  How can I create a stairwell to the attic level?
1) Please fill out your Signature -- see below.
2) The Attic level is not a floor (1st floor, 2nd floor), and you need a floor for a stair to connect to.
Posting images and possibly your plan file will also help with suggestions.
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion
Resources for self help:
I'm having the same problem. I tried to add a 2nd floor but that really messed up my model. I am wanting to build a regular stair case to access the attic, not a second floor.  When adding a 2nd floor, my ceiling heights get modified or my roof gets moved. Since I'm drawing an existing home, these are not things I want done.
A second floor is not necessary.
What are you having a problem doing?
https://www.homedesignersoftware.com/support/article/KB-00358/automatically-building-a-one-and-a-half-story-roof.html
the Tutorial above is the basics...... it will depend on whether you House is built with the Roof coming off the 1st floor wall plates ( see tutorial)  which it probably is if a Converted one or two storey Home Originally.  If they sit on the Floor of the Attic, you will need to Raise the Height so it frames correctly like this.....
Make the Second Floor 1 1/2" ( wall plate thickness) high when you create it not 24" in the Tutorial above ,
in the Roof Build DBX (dialog box)
- check ignore Top Floor
- make the raise birdsmouth setting about 10 1/2" , so the Rafter will sit on the Wall Plate ( created above) on top of the Floor. ( assuming Std HD Floor thickness)
The Stair should now go up and you can create a Stairwell
