Jeff_Rapp Posted August 27, 2017 Share Posted August 27, 2017 Attached is a picture showing a gap in a wall when I have rooms at half height on the wall. It's shown between the lower entrance floor and the floor of the room to the left. How do I fill the gap? I have used Deck as the floor type as I need post & beam floors. I have also attached the plan file. anne1.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 27, 2017 Share Posted August 27, 2017 You can place custom shaped soffits and place them in the wall-floor platform gaps, setting their material to match the wall. That is the most straight forward way to patch such imperfections up. I would first check all room dialog box-structure tab settings and default settings-Current floor settings to see if I had any wrong settings that might be causing the gaps as well. DJP Link to comment Share on other sites More sharing options...
