DeePrice Posted August 16, 2017 Share Posted August 16, 2017 Have a bathroom that is using a secondary base board as the "wainscot"; works well until you build a shower enclosure. I could adjust the tub and add a partition to solve my design issue, but I would like to know that if I was to break the wall in two areas, on each side of the tub, would it eliminate the chair rail and allow me to carry the tile upward to the desired height. See picture for clarification. Wall to right is soffit, not the partition in order to capture crown molding. D.C. Price Home Designer Suite 2018 Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 16, 2017 Share Posted August 16, 2017 You should be able to section off just the tub alcove with a Room Definition Wall (Invisible wall), then program the tub space as you wish. Each room specification dialog has its own "Moldings" tab etc. DJP Link to comment Share on other sites More sharing options...
DeePrice Posted August 16, 2017 Author Share Posted August 16, 2017 Yep, invisible walls are wonderful little creatures and they are so versatile. Link to comment Share on other sites More sharing options...
