Split Drawings and manually Dimension
divreig
The image you posted was drawn using 2D CAD, line by line probably in AutoCAD. Such things can be drawn in Home Designer using its 2D tools, it is easier to do in Home Designer Pro than any other Home Designer title, what do you have? BTW the object you are asking about is used to show that the object above and below in terms of their true length is truncated for the purpose of illustration for the detail.
