Can Not Select, Edit & Delete Custom Countertop & Driveway
Developer
I have a custom counter top, back splash, driveway and front patio that I am unable to select, edit or delete.  It is strange, because I could select some of the pieces that made up a custom island, but now there is a counter top and back splash floating in the kitchen.  Also, the driveway, which is made of paver bricks is visible and but I can not select it to check its dimensions or select the object, at all.  Any ideas?  Help?  Display edit?
Thanks,
Dan
Add - thanks.  It's Home Designer Pro 2018.
Here you can see floating elements from a bar, a entry door wall that was moved forward and the pavers that made up the entry patio that is now further out.  Ideas- they should be polylines for the patio and driveway.
