Monte96 Posted July 5, 2017 Share Posted July 5, 2017 Can anyone help me with creating an offset roof? The back of the house is flat across, but the front steps up about 1 foot almost halfway across. I can't seem to figure out how to manipulate the roof. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 5, 2017 Share Posted July 5, 2017 IF you are using Home Designer Essentials, Suite, Interiors or Architectural you must set the ceiling heights higher so that the roof generator then "knows" to create the roofs higher. (Higher ceiling heights equals higher roof planes) If you have Home Designer Pro you can do the same as above plus just manually raise the roof planes you need to be higher by changing their baseline height figures in their dialog boxes. What software do you have? DJP Link to comment Share on other sites More sharing options...
Monte96 Posted July 5, 2017 Author Share Posted July 5, 2017 I probably should have specified that. Home Designer Suite 2018. Link to comment Share on other sites More sharing options...
Monte96 Posted July 6, 2017 Author Share Posted July 6, 2017 Hi DJP, I tried what you said but as you can see in the pics, it angled the ledge instead of going straight up to the midline. Do you know how to correct this? Link to comment Share on other sites More sharing options...
