Designpronow Posted June 26, 2017 Share Posted June 26, 2017 How do I make the deck railing post to show up in plan view? HDPRO 2018 Thanks, DK 5775 Daltry lane deck.plan Link to comment Share on other sites More sharing options...
LawB10 Posted June 26, 2017 Share Posted June 26, 2017 Is this what you are trying to do? For some reason, in the plan the roof won't build. Daltry Lane.planFetching info... Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 26, 2017 Share Posted June 26, 2017 In Chief Premier you have settings for showing newels, rails and balusters but in Home Designer you have to manually place 2D CAD filled boxes for that purpose in terms of plan view. DJP Link to comment Share on other sites More sharing options...
LawB10 Posted June 27, 2017 Share Posted June 27, 2017 To see the railing posts in plan view, you have use a template that shows them ie: the Cottage template. What you can do is find which template allows the posts to show, copy/paste the rail into the current plan, you can also do that for windows and walls. Also why was the deck built that way? also the rails were 1" thick and used panels. Don't use a deck as landing, use the landing tool. Link to comment Share on other sites More sharing options...
Designpronow Posted July 2, 2017 Author Share Posted July 2, 2017 David Potter, I usually have been using the black cad block for most of the deck newel posts. I just thought I remembered playing around with the railing once before and the post appeared on plan view with out the cad blocks. I may need to upgrade to Premiere one of these days. Thanks for your Reply. LawB10, That process of using an existing template may be the way to go since it saves time and automatically sets the newel post in place. Also, I usually use the deck railing tool as a landing since it also sets the post/piers and decking boards in place automatically. Thanks for the tip. Link to comment Share on other sites More sharing options...
