Make a loft
Lubomir
Hello,
It is my first design.  I made a second floor and "removed" a portion of it to create a loft.  Continued to introduce objects.  Next day I see that I lost the floor on that "loft".  Can I re-introduce it somehow without starting over (which I have done several times already?)  I know other portions of the design have much work to be done on them - that's for later.  Done in Suite.
Thank you in advance!
Luby
Test_1.plan
Thank you, Eric,
I did a "Signature" as you suggested.  I have watched almost all videos, checked the Help and this forum.  There was no suggestions on how to do this, that's why I posted.  I could have missed an answer somewhere.
Rooms are defined by walls. Need a room definition for floors, ceilings etc.
Use a room divider or other wall to extend the railing wall across the gap.
Have you reviewed Park Model homes? They are 400 sq ft, well designed and very livable.
Thank you, Eric,
I didn't think about the version.
I shortened the railing to allow for a stair/ladder and then I saw "no floor".  I'll check your suggestions tomorrow.
Thanks again!
Luby
