displaying 3d object lines versus colors or materials
AdamMalofsky
I want to display objects connected to each other in 3D but not use color or materials.  Rather, I'd like to simply see the lines visible separating the objects.  In this case, a custom patio bluestone layout.   Having objects of the same color look melded is silly.  I'm not sure why this is the default case.
Using Homer Designer Architectural 2018
Help!!
Thanks,
Adam
MalofskyPatioV1.plan
It sounds like from your post that you would like to use different camera modes. Architectural has several: 1. Standard Render, 2. Vector view (either with or without color) 3. Glass House which also has adjustments you can make, 3, Water color. Each of these camera types are adjustable . Based just upon the words of your post, perhaps I  misunderstood but perhaps not.
