Changing Floor Plan Views
jimmimac51
after hitting signature type the info in the box like you do to an e mail  When you hit the print command you should see portrait or landscape in that window . there are  many things that becomes second nature as you keep using the program !! the real gurus will help you more with the proper info !!!  ALL these versions have different features, not to mention how many different type programs this company puts out !!!  IT is   always easier to ask , however going through all the help  files and videos will also help with other aspects of learning the program
If you are using in plan view the "Show Sheet" tool that is controlled by the "File - Print - Drawing Sheet Set Up" in terms of "Drawing Sheet Set up - Landscape or Portrait". This for printing orientation to paper. I rarely use that tool since I mainly use Pro or Premier that have a "Layout Sheet" tool for printing that other Home Designer titles do not have. Let me know if that is the case and what application you are using.
