Ross-Kzoo Posted September 11, 2014 Share Posted September 11, 2014 Is there an easy way to select the materials once you have specified your preferences? For example I want to put a 3' Desert stone veneer ( soffit) all along the front of my house. Is there a way that I don't have to go through all the drop downs each time that I want to select the materials? Link to comment Share on other sites More sharing options...
solver Posted September 11, 2014 Share Posted September 11, 2014 Once you apply your chosen material to a section of soffit, you may save that soffit to your Library (right click - add to Library). Then it is available to use as you would a normal soffit, only with your material already applied. Also, once a material is selected in the library browser, it is available to apply, so a click in the library browser, then a click on the surface to apply. Link to comment Share on other sites More sharing options...
Ross-Kzoo Posted September 11, 2014 Author Share Posted September 11, 2014 Solver, I did try that and wasn't able to do anything when I right clicked on the materials. Link to comment Share on other sites More sharing options...
solver Posted September 12, 2014 Share Posted September 12, 2014 Right click on your soffit after you have applied your materials. You are saving the modified soffit to the library. Link to comment Share on other sites More sharing options...
Ross-Kzoo Posted September 12, 2014 Author Share Posted September 12, 2014 Thanks, that works. I misread what you said. Link to comment Share on other sites More sharing options...
