crosscutter55 Posted April 29, 2017 Share Posted April 29, 2017 i am using home pro 2017 is there a way to have 4 stringers on a set of stair and if so how ?? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 29, 2017 Share Posted April 29, 2017 HD Pro (all versions) are programmed to display either three stringers or a single stringer. This is also true of Chief Premier relative to the stair specification dialog. If you want a fourth one you would have to make such an object in Sketch Up and then import the custom object into HD Pro for manual application to your plan file. I think it would be easier to just annotate with text and an arrow in plan view that one intends an extra stringer than going to a lot of custom 3D modeling to graphically communicate the same thing, your choice. DJP Link to comment Share on other sites More sharing options...
