ChiefUserRobin Posted April 7, 2017 Share Posted April 7, 2017 I'm using Home Designer Pro 2015. I am trying to show a client an entertainment center that fits flush against the back and side walls. The cabinet has crown molding, a "countertop" with a rounded edge profile and base trim. I can't figure out how to delete the molding as it wraps around the side/back of the piece. I've tried placing walls as close to it as I can, but it doesn't seem to be deleting the extra molding on the sides, which are showing up on my elevations. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 8, 2017 Share Posted April 8, 2017 I am sorry to say this is a limitation built into all HD titles. When you assign a molding profile to a cabinet it by default wraps around the front and sides of a cabinet automatically. Only Chief Architect Premier adds the ability to manually create "molding profile poly-lines" that can be edited on each of the poly-lines edges (line segments). DJP Link to comment Share on other sites More sharing options...
