crosscutter55 Posted April 2, 2017 Share Posted April 2, 2017 hi everyone what is the best way to set up multiple pages ? would i have to rename each layout file ?? cape - first floorplan cape second floor plan cape foundation ? could this be all preset in a template ?? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 2, 2017 Share Posted April 2, 2017 In HD Pro that is what you must do: Create a template.layout file with the information on it that you want on each page in the title block area. Open the template.layout and then save-as a copy for each printed page (Floor Plan.layout, second floor.layout, Elevations.layout etc) You order the page numbering to suit your purposes on each .layout file In Chief Premier it is a little easier to do, you just have one .layout file and it contains up to 1,000 blank pages all in one file, the data you want repeated on each page you place on "page zero". Both methods work respectively, you work a little harder in HD Pro is all. DJP Link to comment Share on other sites More sharing options...
