Multi Level Roofs
Ignacio74
I'm new to Home Designer.  Currently using the Pro version.  I love it so far.
  Just wondering how to get the material of the higher walls overlapping lower roofs to completely over lap the roof. Sorry if its confusing. I've attached a photo to demonstrate. Second question.  I need to draw stone columns with an arched entry, also stone,  for my front porch.  I've drawn the roof using room divider tool. Pic attached for this also.  Thanks for any help I can get.
Perspective View 1.pdf
Perspective View 2.pdf
Thank you for your response.  On the first question, if you notice behind the corbel, the stone does not go all the way. There is a little corner showing the stud or interior wall material I suppose.
Maybe I drew it wrong from the start.
I started with all my exterior walls and the roof was all built at the same level.  Then for the bump outs, I added some interior walls to create a small section so that I could change the ceiling ht. for that section. I made those walls invisible because this is the garage we are looking at and I didn't want a small room within the garage.
For the second question, I suppose I can use some square column from the library and change the material to stone, but what about the top section?  I would like the columns and arch to be the same stone material. I've added a Stone Porch pic I found on the internet to show what I am talking about.
Thanks Again.
Perspective View 3.pdf
