BBCfan Posted March 12, 2017 Share Posted March 12, 2017 I'm wanting to raise the second story wall height. Despite reading, watching videos & such, I'm still at a loss as to how to do it with the second story set up as it is. I realize there are many issues with trim & such sticking out of dormers. I may have to finish this in HD 2018 due to my 2017 version just telling me I need to update the license. Try again Home Second Story help.plan Link to comment Share on other sites More sharing options...
BBCfan Posted March 12, 2017 Author Share Posted March 12, 2017 HD 2018 one minute they are fine next minute this. Just tossing this out there. Link to comment Share on other sites More sharing options...
solver Posted March 12, 2017 Share Posted March 12, 2017 How did you build the second floor? One of the parameters is ceiling height, which sets the wall height, which sets the roof height. To raise the walls, you must raise the roof. To raise the roof using automatic roof building, you must raise the ceiling height. To do it manually, select the roof plane you want to raise, click the Transform/Replicate tool, check Move, and enter a z value. Link to comment Share on other sites More sharing options...
BBCfan Posted March 12, 2017 Author Share Posted March 12, 2017 13 minutes ago, solver said: How did you build the second floor? One of the parameters is ceiling height, which sets the wall height, which sets the roof height. To raise the walls, you must raise the roof. To raise the roof using automatic roof building, you must raise the ceiling height. To do it manually, select the roof plane you want to raise, click the Transform/Replicate tool, check Move, and enter a z value. I'll give it a whirl. I built the second floor from the advice on the help pages, Link to comment Share on other sites More sharing options...
BBCfan Posted March 12, 2017 Author Share Posted March 12, 2017 13 hours ago, solver said: To raise the walls, you must raise the roof. To raise the roof using automatic roof building, you must raise the ceiling height. To do it manually, select the roof plane you want to raise, click the Transform/Replicate tool, check Move, and enter a z value. Worked perfectly, thank you! Link to comment Share on other sites More sharing options...
