Wall Under Stairs V 2018
BBCfan
40 minutes ago, solver said:
Be mindful of your ceiling height upstairs.
I raised the backside roof I think, 4'.
I have been working to try to figure it out now for hours over the course of two days. I'm sure I am just missing something, but can't seem to get it figured.
What have you been trying to figure out?
Spend some time learning manual roofs. What you need to do is really simple.
Select the roof plane you want to move. Use the Transform/Replicate tool to move it up or down (z axis). The wall will follow it.
Now in a camera view showing the roof planes, click the ridge of one, press 2, click on the other ridge to rejoin the ridges. If that does not work, select the ridge and pull the roof plane back down towards the eave, then try again.
Open the Roof Plane Specification dialog. On the first panel, you can see where you can change pitch, and various heights. Draw a 1 room structure, put a gable roof on it, then play with the settings to see what each does.
