Wire Railing in Suite Version
jbravo8212
If you were able to find wire railing in a plan that you can open and edit with your version you should be able to copy-paste such selectable objects from one plan to another. You have both plan files open at the same time and then select-copy-paste from one plan file to another. You copy the object in one plan and then switch to the target plan file, go to the "Edit" menu and then select the "Paste" command in the target plan file on the floor of your choice.
