BBCfan Posted February 22, 2017 Share Posted February 22, 2017 I can't get the right dormer to slide anymore to the left. i'm not exactly sure why. I'm under the assumption the roof height is not changing when I slide it side to side. My end goad is to see how it looks with them equal distance from the edge of each roof. This is a work in progress... Thanks for looking at it. Smaller House Flipped Garage.djp1.plan Link to comment Share on other sites More sharing options...
solver Posted February 22, 2017 Share Posted February 22, 2017 Right dormer spaced to match left. Right dormer moved as far to the left as it will go. You do have an unused dormer on the 2nd floor that should be deleted, but I don't think it's causing problems with the one that is visible. Link to comment Share on other sites More sharing options...
BBCfan Posted February 23, 2017 Author Share Posted February 23, 2017 Thanks, I will check the drawing. Perhaps it is causing me an issue. I will try it again. It just stopped dead in it's tracks before. It even started peeling of the siding when I was pushing it over. Link to comment Share on other sites More sharing options...
solver Posted February 23, 2017 Share Posted February 23, 2017 I never use the Dormer tools, instead drawing in my own. With Pro, you have all the tools to do so. Much less frustrating than trying to get the auto dormers to behave. Link to comment Share on other sites More sharing options...
BBCfan Posted February 23, 2017 Author Share Posted February 23, 2017 15 minutes ago, solver said: I never use the Dormer tools, instead drawing in my own. With Pro, you have all the tools to do so. Much less frustrating than trying to get the auto dormers to behave. I understand what your saying, however I have very little experience with the software, so that is a stumbling block for me. As far as I know the roof is the same ptich all the way across. I'm not able to drag it into place & place it with the keys. Link to comment Share on other sites More sharing options...
