LiteMari Posted February 5, 2017 Share Posted February 5, 2017 (edited) ?s on the Electrical Services Specification: There are three angles that can be speced in Light Data: -90 degree Tilt Angle seems to be what is needed for a std. recessed can on a flat ceiling that is aimed straight down, correct? What is Cut Off Angle? Am I correct that this should be set the beam angle of the flood light being used? What is Direction Angle? Altering from the default of 0 degrees to say 60 degrees has no impact in my camera view. It also seems to only accept positive values. Offset The default for From Base is 1/2". Is this the distance the bulb socket is from the top of the recessed can? The default drop off rate is set at 1.5; I assume that this accounts for the lack of uniformity of light dispersion from the center of the beam to the periphery. Is 1.5 a reasonable value to use for a halogen flood light? Can you set the Kelvin for the light source? I see that you can adjust the color with "white" as default, but what RGB would one use for 3000K? Thanks for cutting my learning curve. Edited February 5, 2017 by LiteMari Added ? on Kelvin Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 5, 2017 Share Posted February 5, 2017 Read-Study these help articles please: https://www.chiefarchitect.com/support/article/KB-00777/working-with-light-sources.html This should answer most of your questions. and https://www.homedesignersoftware.com/support/article/KB-01007/controlling-light-sources.html DJP Link to comment Share on other sites More sharing options...
