belmont Posted August 29, 2014 Share Posted August 29, 2014 How do I get an exterior elevation that only shows what you would actually see when you are looking at the house, i.e. no foundation or basement walls showing below the terrain line? Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 29, 2014 Share Posted August 29, 2014 In Home Designer Pro you can alter the terrain skirt thickness to block out the foundation and or when you send an elevation to your layout file you can edit how much of a view shows on that layout using the side-handles to adjust how much shows and what does not show in the view. If you have something other than Home Designer Pro your choices are more limited, what do you have? DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted August 30, 2014 Share Posted August 30, 2014 The easiest thing to do with things like that is to make a CAD BOX and assign the box Fill and Line colour to be the same as your Background colour , (making it invisible except when selected.) which will blank out the unwanted Foundation. I'm using Pro , don't know what you have ? but think this should work in most Versions... Mick. Link to comment Share on other sites More sharing options...
Keith_K Posted September 2, 2014 Share Posted September 2, 2014 Tools>Display Settings>Display options Uncheck foundations, footings and anything else you don't want to see. That's what I do. Link to comment Share on other sites More sharing options...
belmont Posted September 10, 2014 Author Share Posted September 10, 2014 Thanks for the replies. I have Pro. Link to comment Share on other sites More sharing options...
