PeterMD Posted January 22, 2017 Share Posted January 22, 2017 When I try to mull two windows vertically, it won't do it. I have the Vertical Stacking Levels set to zero for the bottom one and to 1 for the upper one. See attached image. If I place them side by side with equal sill heights, then dragging them together WILL mull them. See two images of that. One odd thing I found was that the Interior Casing width has to be set roughly equal to or larger than the minimum window spacing (1" by default). Otherwise no mulling at all. This is regardless of the presence of the exterior casing. See image where the right window interior casing has been set to 1/4" and they won't mull. In my case I wanted to have ONLY exterior casings, but it looks like it won't let me mull that way. BTW, in these images I've set the exterior casing materials to odd colors to clarify which is which. Note that when they join (mull), the left window's casing color "takes over" the smaller window. For the over-under mulling I wanted to have an awning on the bottom and fixed on the top. Any way to do that in Pro? Peter Link to comment Share on other sites More sharing options...
PeterMD Posted January 22, 2017 Author Share Posted January 22, 2017 I guess I could eliminate the exterior casing as well, and "build" the full surrounding exterior casing I want using rectangular blocks (box shapes); but wow, that would be a whole lot of work! Link to comment Share on other sites More sharing options...
solver Posted January 22, 2017 Share Posted January 22, 2017 1 Link to comment Share on other sites More sharing options...
PeterMD Posted January 22, 2017 Author Share Posted January 22, 2017 Thanks Eric! You the man! I wondered what "Component Options" meant-- for some reason the term "components" never implied separate sashes to me; I assumed it had something to do with wooden or metal small parts. Should have just tried it! No excuse for failure to explore 100% of the available options!! That creates exactly what I need! Peter Link to comment Share on other sites More sharing options...
