midway22 Posted December 19, 2016 Share Posted December 19, 2016 Hi guys, I have been scouring for an answer to this problem but so far all the porch, roof and other tutorials/answers haven't covered it. I am trying to add a rear addition to a cape cod which has a fully bumped out shed dormer on the second story. So far it freaks out when I try to setup the first floor addition as upper/lower pitched shed roof. Seems that when there is a dormer in the roof the auto roof from the addition doesn't like butting into it. If anyone has an idea or suggestion, I am all ears. Thanks in advance! exterior.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 19, 2016 Share Posted December 19, 2016 I have completed a You Tube video of "fixing" your plan in Suite 2017 and in Pro 2017 so you can clearly the limitations of Suite. I am sorry but it is what it is. DJP 1 Link to comment Share on other sites More sharing options...
midway22 Posted December 19, 2016 Author Share Posted December 19, 2016 David, that took entirely too long to respond, ha, jk! Thanks so much for the explanation and it makes perfect sense. I assumed that the version limitation was what I was running into as this is a semi complicated roof/siding junction. I do one home remodel for myself or flip about every 5 years, so I use Home Designer fairly infrequently. I think if I totaled my bill rate for the time spent messing with Home Designer version problems, I could have already bought Pro so I think that might be coming down the line. thanks again for the quick response Link to comment Share on other sites More sharing options...
