MikeGruby Posted November 29, 2016 Share Posted November 29, 2016 What is the simplest way to start a new interior design remodel plan using "Space Planning" blocks and not show the whole house? Link to comment Share on other sites More sharing options...
solver Posted November 30, 2016 Share Posted November 30, 2016 Not sure what you are asking, or what you are wanting to do. Link to comment Share on other sites More sharing options...
MikeGruby Posted November 30, 2016 Author Share Posted November 30, 2016 I want to do a complete interior remodel of an existing condo. Gut the walls. Can I use the "Space Planning" tools to arrange the spaces, then create only the rooms. The normal process is to then select "Build House" and an entire house is created. I guess I can do that, then deselect all of the extraneous boxes in the "Display Options". I'm looking for a quick way to start the process from the "Space Planning." Link to comment Share on other sites More sharing options...
solver Posted November 30, 2016 Share Posted November 30, 2016 You would need exterior walls to act as boundaries. Draw them in the standard mode, then switch to space planning. You can freely switch back and forth -- you are not required to "Build House". Once you have a plan you like, just add walls. Link to comment Share on other sites More sharing options...
MikeGruby Posted November 30, 2016 Author Share Posted November 30, 2016 Thanks Eric. The "Build House" process automates the wall building process for the first pass. I want to keep that step. Link to comment Share on other sites More sharing options...
katalyst777 Posted November 30, 2016 Share Posted November 30, 2016 KB-00121: Using the Space Planning Assistant Link to comment Share on other sites More sharing options...
MikeGruby Posted November 30, 2016 Author Share Posted November 30, 2016 Thanks. Link to comment Share on other sites More sharing options...
