NxLhomes Posted November 27, 2016 Share Posted November 27, 2016 I am new to the forum but I search for this answer here, in the knowledge base, and the manual but cannot find. I see that there were Q&As about this when I google, but it appears that this was with the old forum database so I cannot access. Q: I checked the box in the foundation defults for treated sill plate, and I have it check in the display options, but I absolutely cannot get it to show in any view, 3D perspective, Framing, etc. I end up making my stem wall height 1 1/2" taller to compensate. Is there a solution to this? Any help would be appreciated. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 28, 2016 Share Posted November 28, 2016 I assume that you have Pro so what you need to now do is build framing. DJP Link to comment Share on other sites More sharing options...
NxLhomes Posted November 28, 2016 Author Share Posted November 28, 2016 David, Thanks for responding. I do have Home Designer Pro 2015. I did build framing but there is still no Sill Plate showing in the Framing perspective overview with all levels checked to display. I just noticed something that I did not before. In the "Layer display options" panel, there is no "+" sign in the "used" column. I clearly have Treated Sill Plates checked in the Foundation Defaults, I rebuilt walls, then deleted and rebuilt wall and floor framing. There is something fundamental I'm not understanding about the Sill plate and SWT. In my foundation room definition of Garage, I am giving 21 1/2" for SWT...that is 20" from slab and 1 1/2" for Sill plate. Not sure that is correct, but the math does not seem to work without it. Link to comment Share on other sites More sharing options...
