Terrain problem
SAILOR139
Thanks David.  I have tried several variations.  But, for some reason it always appears the driveway is fixed to the foundation and will not become flush at the garage floor.  I have set the terrain spec pad elevation to the same level as the garage and everything works right; however, I don't think this is how it should be done.
This terrain dialogue is very confusing to me.  I have reviewed one of your YouTube tutorials; I guess I need to do more.
You have two choices: 1. You can make the driveway object a little thicker via is dialog or 2. and this is what I usually do, I raise or lower the terrain plane so the driveway object aligns with the terrain plane. I usually do that as soon as I create the terrain plane. Adjusting the terrain elevations is then done.
